您的位置:控制工程论坛网论坛 » 产品供求 » 日本NSK气钻SPINDLE-气动马达,NSK气钻,SPINDLE-气动马达,宏盛国际
hs889
hs889   |   当前状态:离线
总积分:126  2025年可用积分:0
最后登录时间: 2010-11-26
hs889  发表于 2010/11/26 18:10:04      736 查看 0 回复  [上一主题]  [下一主题]
NSK气钻广泛应用于CCD/X-RAY钻靶机及金手指斜边机,宏盛国际发展有限公司为NSK的一级代理商,低价销售、维修NSK气钻,保证价格低、品种全、交货快。
NSK气钻SPINDLE
编号 气钻名称 外径 转速 功率
1021 AM-300R 22.8mm 30,000min-1(rpm) 57W
1083 AM-300L 22.8mm 30,000min-1(rpm) 57W
1018 AM-300RA 22.8mm 30,000min-1(rpm) 57W
1084 AM-300LA 22.8mm 30,000min-2(rpm) 57W
1079 AM-310R 22.8mm 30,000min-2(rpm) 108W
1085 AM-310L 22.8mm 30,000min-2(rpm) 108W
1081 AM-310RA 22.8mm 30,000min-2(rpm) 108W
1082 AM-310LA 22.8mm 30,000min-2(rpm) 108W
1071 AM-600R 22.8mm 58,000min-1(rpm) 76W
2512 AM-600RA 22.8mm 55,000min-1(rpm) 69W
8220 NR-2351 22.8mm 30,000min-1(rpm)
1020 NR-301 22.8mm 30,000min-1(rpm)
1020 NR-2301 22.8mm 30,000min-1(rpm)
2511 NR-310 22.8mm 30,000min-1(rpm)
1073 NR-601 22.8mm 60,000min-1(rpm)
1801 AM-2526R 25mm 24,000min-1(rpm) 130W
1802 AM-2526L 25mm 24,000min-1(rpm) 130W
1803 AM-2526RA 25mm 22,000min-1(rpm) 120W
1804 AM-2526LA 25mm 22,000min-1(rpm) 120W
 8333
 EM25-5000-J4
 25mm
 50,000min-1(rpm)
 125W
1819 NR-2551 25mm 50,000min-1(rpm)
1809 NR-2532 25mm 30,000min-1(rpm)
1797 AM-3020R 30mm 19,000min-1(rpm) 130W
1798 AM-3020L 30mm 19,000min-1(rpm) 130W
1799 AM-3020RA 30mm 18,000min-1(rpm) 125W
1800 AM-3020LA 30mm 18,000min-1(rpm) 125W
9027 EM-405 30mm 40,000min-1(rpm) 270W
1565 NR-402E 30mm 40,000min-1(rpm)
1565 NR-403E 30mm 40,000min-1(rpm)
1566 NR-453E 30mm 50,000min-1(rpm)
1534 AMS-20R 53mm 2,200min-1(rpm) 131W
1528 AMS-50R 53mm 4,000min-1(rpm) 131W
1529 AMS-150R 53mm 15,000min-1(rpm) 132W
1530 AMS-250 47mm 25,000min-1(rpm) 105W
Company:宏盛国际发展有限公司
TEL:86-0512-55177726,55177728
FAX:86-0512-55177725
E-MAIL:hs-889@163.com
