您的位置:控制工程论坛网论坛 » PLC与PAC » PLC英语
zhangyue
zhangyue   |   当前状态:在线
总积分:720  2025年可用积分:0
最后登录时间: 2017-06-13
PLC英语
zhangyue  发表于 2010/12/8 14:56:17      2401 查看 2 回复  [上一主题]  [下一主题]
        单词 解释 例句或者词组 音标
        abbrivation 缩写 [?,bri:vi`eifn]
        absolute 绝对 absolute output 绝对最大输出 [`aebs?lu:t]
        actuator 执行器
        against 对比 i/o signals against pc cpu
        allocate 分配 allocate the user area in buffer memory [`ael?keit]
        alter 改变 even if the output characteristic is altered by changing offset/gain setting [`o:t?]
        ambient 环境 周围 ambient operating temperature [`aembi?nt]
        analog 模拟 analog output [`aen?log]
        analysis 分析 the collection an and analysis of data [?`nael?sis]
        applicable 可用 the applicable cpu for the module
        assign 分配 the teacher has assigned each of us a holiday task. assign i/o number [?`sain]
        back up battey 备用电池
        barcode reader/id 条形码阅读器
        base unit 主基板
        baud 波特 [bo:d]
        beforehand 事先
        binary 二进制 12 bit binary  [`bain?ri]
        buffer memory 缓冲存储器
        bus 总线
        case 外壳 do not remove the modules print board from the case
        characteristic 特征 i/o characterristic [`kaer?kt?`ristik]
        check 校验 the data link status canbe checked
        child-station 子站
        common terminal 公共端
        compatible 兼容 compatible with the modbus protocol
        compound 混合 compound system communication [`compaund]
        condensation 结露
        condition 条件 condition setting
        conductive 导电 conductive metal picees
        configuration 组态 system configuration
        configure 组态
        confirm 确认 how to confirm the operation of the module
        consumption 消耗 current consumption [k?n`s^mp∫n]
        content  目录
        control level 控制级
        convenient 方便 more convenient and easy-to-use
        conventionaly 传统 which conventionaly has been used [k?n,venfenael?ti]
        conversion 转换 analog-digital conversion module
        converter 转换器 [c?n`v?:t?]
        conveyor 传送 conveyor line [c?n`vei?]
        corrosive 腐蚀 corrosive gas [k?`r?usiv]
        countermeasure 对策 countermeasure for mis-inpute
        cutoff 切断
        debug 调试 is recommended before debugging
        dedicated 屏蔽 cc-link dedicated cable
        dedicated 专用 dedicated transmission protocol
        default value 缺省值
        define 解释 阐明  offset value and gain value are defined as follow. [di`fain]
        design 设计 design a system
        device level 现场级
        diagnosis 诊断 diagnosis function [dai?g`n?usis]
        digital 数字 digital inpute
        din rail 导轨
        diverse 不同的各种各样的 a diverse application requirements [dai`v?:s]
        download  下载
        duplicate 完全一样 [`dju:plik?t]
        dust 灰尘
        eliminate 免得 [i`limineit]
        enterprise level 管理级 [`ent?prais]
        erase 清除
        exceed 超出 the number admitted must not exceed 200 [ik`si:d]
        execute 执行 date link is executed using these parameters [`eksikju:t]
        expand 扩展 can be eapanded up to 255 networks
        faulty  故障站
        field bus  现场总线
        fix 固定
        flexibly 灵活的 to support a variety systerm flexibly [`fleks?bli]
        flow 流量
        format 格式 transmission format [`fo:maet]
        frame
        fuse 融丝
        graph 图标 坐标图 曲线图 voltage output characterristic graph [gra:f]
        guaranteed 担保 nomal operration cannot be guaranteed [,gaer?`ti:d]
        handle 处理
        hardware manual 硬件手册
        hint 提示 programming hints
        humidity 湿度 ambient operating humdlity
        individual 独立的
        inductance  电感 inductance load
        initiate 实施 发起 can be initiate by a computer [i`nifieit]
        input  输入
        input point 输入点数
        install 安装
        instruction 指令 the from instruction
        insulation 隔离 form rubber provides good insulation [,insju`leifn]
        interface 接口 [`int?feis]
        interlocking 互锁 can be used for sequence program interlocking
        internal external 内部 外部 internal connection
        interrupt 中断 excute an interrupt processing
        invalid 无效 error invalid station function
        magnetic 有磁性的 magnetic fields [maeg`netik]
        main circuit 主回路 [`s?:kit]
        malfunction 故障 cause system malfunction
        mandatory 强制 [`maed?t?ri]
        mantenance 维护 maintenance costs are reduced [`meit?n?ns]
        manual 手册 user manual
        mechanical 机械 michanical life机械寿命
        module  模块 mount or remove the module [`modju:l]
        momentary power failure 瞬时断电
        monitor 监视
        mount 固定  mount or remove the module
        multiple 多样 mutiple remote i/o modules
        negative  负
        observation 观察 [obz?`veifn]
        occupy 占用 occupies 1 station [`okju:pai]
        occur 发生
        offline 离线 offline test
        offset gain 偏置增益
        oil mist 油雾
        optical loop 光缆回路 [`optik?l]
        optimum 最佳的 optimum control [`optim?m]
        output 输出
        overall 总的 overall distance
        overview 总揽 communication overview
        parameter 参数
        path 路径 transmission path
        per network
        perform 进行 normal data link cannot be performed
        performance specifations 性能规格
        peripheral 外围 when utilizing peripheral device to assign i/o number. [p?`rif?ri?r?l]
        phase 相 swith off all phases of the power supply [`feiz]
        photocoupler
        point 要点
        port  口 rs232c port
        positive  正
        power line 电源线
        power on/off 上电断电
        precaution 注意事项 precaution when configuing system
        print board 印刷电路板 do not remove the modules print board from the case
        procedure 过程 follow the procedure
        programing interface 编程口
        protocol 协议 protocol communication issues [`pr?ut?col]
        range 范围
        rated input voltage 额定输入电压
        ratio 比率 [`reifi?u]
        recommend 建议 is recommended before debugging
        reduce 减少 the number of steps in operation program can be reduced
        refer to  参照 refer to chapter 6
        register 数据寄存器
        relay 继电器 [`ri:lei]
        remote i/o 远程网络io [ri`m?ut]
        reserved station 预留主站
        resin 树脂 made of resin
        resistor 电阻 resistor load阻性负载  terminating resistor [ri`zist?]
        resolution 分解,解析 n maximum resolution  最大分辨率 [,rez?`lu:fn]
        restriction 限制 no restriction [ri`strikfn]
        retry 从试
        scan 扫描 link scan
        screw 螺丝 teminal- block screw
        seamless network 无缝网络
        sequence programme 顺控程序
        serial communications module 串口模块
        series 系列 ans series [`si?ri?s]
        servo 伺服
        short 短路
        signal 信号
        sink 漏极 sink commen
        slot 槽
        soures 源极 soures commen
        specifications 特性 input modules specifications
        stabilized power supply 稳压电源 [`steib?laiz]
        standby master station 备用主站
        start up  起动
        status 状态 data link status
        step drive 步进
        storage 存储 storage area
        store 存储
        switch off 关断 swith off all phases of the power supply
        swith 开关
        table 表格
        transfer 传输
        transistor 晶体管
        transmission speed 传输速度
        transmit 传送 data is transmitted in unchanged code
        triac 双端三相可控硅开关
        troubleshooting 故障处理
        unuseble 不可以使用
        upload 上传
        utilize 利用 when utilizing peripheral device to assign i/o number. [`ju:t?laiz]
        verify 校验 verify the set parameter contents
        voltage 电压 high voltage [`v?ultidg]
        watchdog 看门狗
        width 范围 it will vary in the width of [widθ]
        wire chips 线头 do not let foreign matter such as wire chips ret inside the module
  • lyc19730508
    lyc19730508   |   当前状态:在线
    总积分:21348  2025年可用积分:3
    最后登录时间: 2021-05-27
    lyc19730508   发表于 2010/12/8 16:05:22
    好资料库
    引用 lyc19730508 2010/12/8 16:05:22 发表于2楼的内容
