您的位置:控制工程论坛网论坛 » 产品供求 » TOSSTAR@163.COM供应二手网络HP3577A (5Hz-200MHz 网络分析仪)
july2007
july2007   |   当前状态:离线
总积分:69  2025年可用积分:0
最后登录时间: 2007-02-02
july2007  发表于 2006/12/12 14:53:04      768 查看 0 回复  [上一主题]  [下一主题]
Agilent/HP 3577A
  • Agilent/HP3577A (5Hz-200MHz 网络分析仪)
  • 欲购买或租赁Agilent/HP 3577A?请在线咨询或拔打电话:13332662998,欧阳总经理
Agilent/HP3577A缩略图
品牌型号: Agilent/HP3577A 库存状态:现货
类别: 网络分析仪 -> 500MHz以下网络分析仪
QQ:152623914
相关技术文档:
HP3577A 用户使用手册
详细资料:
  • 5 Hz to 200 MHz
  • High Speed/high accuracy measurements
  • 0.001 dB, 0.005 degree, 1ps, 0.001 Hz resolution
  • Built-in three-term error correction plus normalization
  • Magnitude, phase, polar, real, imaginary, and group delay display modes
  • Convenience features including direct plotter control and vector math functions
  • GPIB
The HP 3577A Network Analyzer provides cost-effective, high performance network measurements from 5 Hz to 200 MHz for higher productivity in design and production. The companion HP 35677A/B S-Parameter Test Sets and full line of accessories ensure a complete measurement solution. Innovative analog and digital design are combined for superb accuracy, resolution and operational simplicity.
Convenient soft-key selection of measurement functions allows you to quickly measure transfer functions, magnitude/phase, insertion loss/gain, attenuation, electrical length and gain compression. In addition, measurement of phase distortion parameters such as group delay and deviation from linear phase can be made with high resolution. With the HP 3577A's flexible receiver input impedances, you can measure in either 50 Ohm or high impedance (1 Megohm) environments. Use the HP 35677B S-Parameter Test Sets with the HP 3577A to make reflection measurements such as return loss, reflection coefficient and impedance in 50 Ohm or 75 Ohm systems, while simultaneously displaying transmission parameters
仪器保证:
保修期限:保修一年,终身服务!
