您的位置:控制工程论坛网论坛 » 仪器仪表 » Most proficient Drum Machine Software sounds should reach well into the thousands
monster88
monster88   |   当前状态:在线
总积分:68  2026年可用积分:0
最后登录时间: 2013-09-09
monster88  发表于 2013/7/12 10:10:00      744 查看 0 回复  [上一主题]  [下一主题]
Chronology: Similar to music on a digital audio device, the timeline
scrolls from left to right as it progresses. The software's on screen
interface has a timeline that lets you to see that everything's on track
and in time. Lines are used to mark these time segments,Beats By dre Spiderman
these are points of reference for you to use. You will decidedly insert
the notes you want played in the segment in the timeline where you want
them to be read.
Track: This is where each sound in a space along the timeline gets
played. The tracks are displayed on the left side, top to bottom. Each
spot of a track that you place a note in will play a sound. For
instance, the kick, snare,Beats Spiderman Diamond
and hi hat each have their own tracks, they can be registered to switch
on at eccentric rates in different sections of the timeline.
Sound Bank: The sound collection is where you select from a databank
of instruments and/or drum parts in which you can then assign each of
them to the area you want them to be in your beat. Most proficient Drum
Machine Software sounds should reach well into the thousands. With 100s
of varied snares, bass kicks, hi hats, claps, sound effects, and
instruments at your disposal for you to put in your musical piece, you
are only dwarfed by your own talent.
