您的位置:控制工程论坛网论坛 » 招聘求职 » Structure Inspector - Wuhan
ieces
ieces   |   当前状态:在线
总积分:296  2025年可用积分:0
最后登录时间: 2015-08-17
ieces  发表于 2009/4/15 13:34:48      1185 查看 0 回复  [上一主题]  [下一主题]
We have an inspection assignment at Wuhan for a large fabrication job. The Large Fabrication is now in full production and the contract is expected to last a minimum of 12 months.
The inspector we are looking for is a local base inspector that is available to visit the supplier production facilities as required on a periodic (2-5 days per week) basis and have the following qualifications.
1.       The inspector should have at least 5 years experience in the inspection of large fabrications an/or Process Equipment including visual inspection, verification of tie in points, dimensional inspection, Bolt Hole Patterns, paint systems Etc.
2.       The inspector should have experience in inspection of welding and fabrication.
3.       The inspector should have experience in the witnessing of NDT and also the interpretation of Radio graphs.
4.       The inspector should have experience in shop inspection of Pressure Boundary piping and components in accordance with the ASME Code.
5.       The inspector should have experience in the review, implementation, and resolution of non-conformance between the supplier and the client.
6.       The inspector should be able to challenge the supplier on the quality issues and the quality of the work and should also be able to work with the supplier and the client to resolve any quality issues.
Please provide me a quotation based on following options,
l       Lump sum day rate (inclusive of travel, meals, accommodation and tax etc)
l       Lump sum monthly rate (based on residence at Wuhan and inclusive of travel, meals, accommodation and tax etc).
If you are suitable for the said requirement, Do not hesitate, Please send your latest ENGNGLISH CV.doc and your related Certificates.jgp to us: EPCHR01@126.com!
