您的位置:控制工程论坛网论坛 » 产品供求 » 供应各种Instec产品
359528711
359528711   |   当前状态:离线
总积分:55  2025年可用积分:0
最后登录时间: 2009-06-25
供应各种Instec产品
359528711  发表于 2009/6/25 11:52:19      663 查看 0 回复  [上一主题]  [下一主题]
一. 显微镜冷热台台
Instec显微镜配套冷热台的专业设计是针对液晶产品的,可提供多种尺寸/温度区间的选择,拥有多种独有特性以适应客户的不同需求,如不同样品区不同加热温度,大观察窗,电子探头接入Instec’s microscope thermal stages are designed specifically with liquid crystal applications in mind. Our heating and cooling stages offer many features which are unique in the market place, such as dual heating with variable sample chamber height, large viewing aperture, and easy electrical access to the sample.
二. 加热/制冷盘
标准 Instec冷热盘尺寸从 20mm 到 300mm ,并可根据客户需要增大到 600mm。温度区间为 -190oC to 600oC,或更高, 高度的温度均匀性和稳定性(温差小于 ±0.1oC)。另备有三维加热器消除电子噪声影响。可选择固定表面或空气悬浮表面。Standard sizes of Instec thermal chucks range from 20mm to 300mm (custom sizes are available up to 600mm). Temperature ranges for standard models are available from -190oC to 600oC, with higher temperature limits available for custom hot chucks. Instec hot and cold chucks provide ultra temperature uniformity and stability (better than ±0.1oC). An optional triaxial heater is available for eliminating electrical noise. The hot chuck surface is available as a grounded or floating surface.
三. 加热/制冷台
标准冷热台尺寸区间为20mm到300mm,可根据客户需求定做。可控温度区间为-190oC to 600oC ,或更高,加热均匀稳定。同时提供密封罩用于除霜排气。Standard sizes of Instec thermal plates range from 20mm to 300mm (custom sizes are available upon request). Temperature ranges for standard models are from -190oC to 600oC, with higher temperature limits available. Instec hot and cold plates provide ultra temperature uniformity and stability. Instec also offers gas tight covers for defrosting or gas purging
四. 冷热盘台附件
可编程温度控制器
液氮冷却剂接入器
循环冷却液接入器
五. LCD仪器ALCT - the Automatic Liquid Crystal Tester has up to two independent channel, high voltage, arbitrary waveform function generators (±100V and 1MHz) and up to four real-time digital scope channels. The ALCT can perform automatic measurement of various liquid crystal parameters. VHR - the Voltage Holding Ratio Measurement System, RDC - the Residual DC Measurement System and Photo Detector are available too. Custom configurations for special measurements are also available.
六. LC器件Instec empty cells are manufactured in clean rooms. The adhesive can withstand temperatures up to 200°C. All cells have a patterned ITO area, 5mm X 5mm, with ITO resistance = 100ohms per sq. Alignment layers are of 1° to 3° pre-tilted angles. Physical dimensions and spacing of cells vary depending on the models. Cell gap tolerance is ±0.2 μm.
七. 显微照相机
分辨率2M到12M。Instec's C-mount microscope digital cameras feature temperature stamping on the captured image. Resolutions range from 2 to 12 Mega pixels.
八. 显微镜附件
长焦偏振电容器LWDC系列,为焦距20mm,可调,可分离、旋转偏振器,可与绝大多是竖直型光学显微镜配套。Instec’s long working distance polarizing condensers, LWDC series, feature 20mm working distance; detachable and rotatable polarizer; universal dovetail fitting compatible with most major upright optical microscopes; adjustable condenser aperture Iris. The LWDC series is ideal for thermal microscopy applications.
中电网EMD是从属于信息产业部CCID的从事国际半导体制造设备与材料引进及介绍的专业代理机构;
详细信息请电话或邮件联系EMD上海办事处或者前往网站
联系人:王小姐/陈先生
电话:021-61021226
电邮:wangdongmei@eccn.com/benchan@eccn.com
