您的位置:控制工程论坛网论坛 » 产品供求 » CT-8685精密线材测试机/线材综合测试仪CT8685系列产品
xnt002
xnt002   |   当前状态:在线
总积分:468  2026年可用积分:0
最后登录时间: 2014-09-12
xnt002  发表于 2012/2/9 13:39:31      657 查看 0 回复  [上一主题]  [下一主题]
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市欣诺特电子仪器有限公司<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"><SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">地址:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">深圳市宝安区龙华镇民治碧水龙庭<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">6<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">栋<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">TEL<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29737880
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">FAX<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">0755-29738815
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">联系人:<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana"> <SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">手机:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">QQ<SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">1780114589
<P .="MsoNormal"><SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">E-mail: xnt008@126.com<SPAN .="mso-spacerun: yes">
<P .="MsoNormal"><SPAN .="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-ascii-font-family: Verdana; mso-hansi-font-family: Verdana">张先生:<SPAN lang=EN-US .="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">13652350058
精密线材测试机CT-8685系列产品特点:
系统提供中文操作介面
开机自我诊断,自我校正
系统可自动扫描自动找点
系统提供先进的瞬间断短路/导通测试
可作线材单边测试/绝缘测试
最高AC1000V/DC1500V测试电压
最高可测256测试点
提供320×240解析度图形液晶显示
线性与安规测试一应俱全
完全可分段连续测试
提供多种介面,可作各种不同之应用
系统提供统计与电脑连线列印功能
精密线材测试机CT-8685系列技术参数:
项目 符号 测试范围
电阻 R 0.1Ω-10MΩ
电容 C 10pF-1μF
二极体测试 D 0.0V-7.0V
遮蔽率(For/+) Shielding Rate 0.0-100.0
导通 COND 0.1Ω-50.0Ω
绝缘电阻 I.S 1MΩ-1000MΩ
高压(漏电流) IL 0.1mA-5mA
断/短路 O/S 2KΩ-50KΩ
瞬间断短路测试
瞬间导通测试
单边测试
断短路端点判断
进阶功能 可程式化连续测试
自动学习与自我找点
自我诊断
自我校正归零
统计显示与列印功能
基本准确度 ±1%
测试扫描模式 自动/手动扫描可切换
量测速度 0.1Sec基本值
量测频率与讯号/电压 100~100KHz,1Vac
低电压量测讯号 5Vdc,50mA Max
准确度±0.5%
高压(漏电流)测试 100~500Vac(NA机种)
100~1000Vac(FA机种)
0.01~60Sec Delay时间设定
高压绝缘测试 200~1000Vdc(NA机种)
200~1500Vdc(FA机种)
准确度±0.5%
显示/声音装置 320×240解析图形液晶显示
6位数数位显示
Pass/Fail LED红线指示灯/画面显示/声音
量测接点 128独立量测接点
可选择256接点
高压校正正负端输出
自动找点端子
控制面板 系统/快速/编辑/功能/按键群组
界面 RS-232通信连接埠
印表机埠
远端控制埠
记忆装置 内建512KB SRAM
内建备份电池
电源供应 115/230Vac可切换式电压输入±10%
60/50Hz
配件 自动找点探针
远端控制线(选购)
RS-232通讯线(选购)
治具排线
电源线
使用手册
温湿度 摄氏15℃~35℃
相对湿度≤75%RH
尺寸(宽×高×深) 425×190×350mm
重量 约14Kg(不含配件)
线材规格要求 最高1μF
CT-8685NA AC500V/DC1000V
CT-8685FA AC100V/DC1500V
CT-8681FA AC500V/DC700V
/C2 选择256测试点
