您的位置:控制工程论坛网论坛 » 工业以太网 » 泓格I-7514U
szsxry
szsxry   |   当前状态:在线
总积分:405  2026年可用积分:0
最后登录时间: 2021-12-24
泓格I-7514U
szsxry  发表于 2018/11/30 14:55:11      1216 查看 0 回复  [上一主题]  [下一主题]
产品介绍: 4路隔离RS-485有源集线器
产品特点:
  • True RS-485 Star Wiring Hub
  • Independent RS-485 driver for each channel
  • LEDs for indicating RS-485 TxD/RxD activity
  • Auto Switching baud rate, 300 ~ 115200 bps and fixed baud rate setting via rotary switch, 1200 ~ 115200 bps
  • Hubs can be daisy chained for 256 channels
  • 120Ω termination resistor for each channel
  • Power Input, +10 ~ +30 VDC
  • Operating Temperatures, -25 °C ~ +75 °C
  • DIN-Rail
产品规格:
Interface
Input (Master)1 RS-485 Channel: Data+, Data-
Output (Slave)4 RS-485 Channels: Data+, Data-
Transfer DistanceMax. 1,200 m at 9.6 kbps; Max. 400 m at 115.2 kbps (Belden 9841 2P twisted-pair cable, if different cables are used, the transmission distance may change)
Self-Tuner Asic InsideYes
Speed300 ~ 115200 bps via Self-Tuner mode; 1200 ~ 115200 bps via Fixed Baud Rate mode
ESD ProtectionYes
2500 VDC Isolation on CH1 ~ CH42-way Isolated
ConnectionRemovable 10-Pin Terminal Block x 1; Removable 6-Pin Terminal Block x 1
LED Indicators
Power/Communication(TxD/RxD)Yes
Power
Input Voltage Range+10 VDC ~ +30 VDC (Non-isolated)
Power Consumption1.2 W
Mechanical
CasingPlastic
FlammabilityFire Retardant Materials (UL94-V0 Level)
Dimensions (W x H x D)72 mm x 122 mm x 35 mm
InstallationDIN-Rail
Environment
Operating Temperature-25 °C ~ +75 °C
Storage Temperature-30 °C ~ +80 °C
Humidity10 ~ 90% RH, non-condensing
